8Sinn 8-ANV Overview
The 8Sinn Cage for Atomos Ninja V Monitor is an aluminum cage with integrated accessory mounting holes specifically designed for the Atomos Ninja V recording monitor. The cage features mounting holes on the top and bottom that align with your camera's top and bottom 1/4"-20 mounting points, as well as two locating pins that help prevent the camera from twisting in the cage. A built-in cold shoe and threaded 1/4"-20 mounting holes allow you to mount accessories.
The cage allows access to all camera functions as well as battery and media doors, and it has slots that allow you to add a neck strap. An included HDMI cable clamp mounts on the side of the cage and is adjustable to fit your HDMI cable.
* Monitor is secured via the top and bottom 1/4"-20 mounting points
* The included HDMI cable clamp helps prevent accidental kick-outs of an attached HDMI cable.
SKU: 8-ANV C
$95.00 Regular Price
$61.75Sale Price
    • Form-Fitted Armored Cage
    • Built-In NATO Rails
    • Anti-Twist Locking Pins
  • Mounting
    Included Adapter
    1 x 3/8"-16 Thread to 1/4"-20 Thread Reducer Bushing
