8Sinn 8-A7SIII C+8-THP Overview
The Cage for Sony a7S III/a7 IV with Top Handle Pro combines a formfitting protective cage with an adjustable top handle that offers side-to-side and front-to-back balance adjustments. The cage features numerous 1/4"-20 threaded accessory mounting holes, and it protects your camera from the stress of attaching accessories while leaving you access to your camera's controls and functions.
The Top Handle Pro mounts on top of the cage via an included NATO rail that you attach to your cage. This provides a solid connection between the handle and cage and allows you to adjust the balance side to side, as well as slide the handle off when not using it. The top handle grip is a shaft that you can easily slide forward and back as well as remove and reverse from the NATO rail mount. This allows you to adjust the balance of your camera when carrying by the top handle front and back. The top handle grip has cold shoes on top as well as the front, and the back of the grip has an opening for a 15mm rod. The top handle grip is also replete with 1/4"-20 and 3/8"-16 threaded mounting holes.
8Sinn Cage for Sony a7S III/a7 IV
Protecting your camera from the rigors of production while providing multiple accessory mounting points is the purpose of the 8SINN Cage for Sony a7S III/a7 IV. Your camera mounts onto this formfitting cage with a 1/4"-20 slot and raised tabs at the front prevent your camera from twisting. The cage allows access to the camera's controls and hot shoe, and the base features a multitude of 1/4"-20 mounting holes, as well as a single 3/8"-16.
In addition to one integrated cold shoe and multiple 1/4"-20 threaded holes distributed along the sides and top of the cage, the cage also sports a 3/8"-16 threaded hole with ARRI-style anti-twist divots on its top. Strap slots allow you to attach a camera strap if you wish, and you can use the  included 2.5mm screw to secure your camera to the cage via your camera's eyelets to help prevent it from shifting in the cage. Threaded mounting holes in front of the cage enable mounting optional lens adapters.
Compatibility
Sony a7S III and a7 IV mirrorless cameras
8Sinn Top Handle Pro with NATO Rail (2.4")
The 8Sinn Pro Top Handle mounts easily on your camera cage using the included 2.4" NATO rail. The NATO rail mount makes it easy to attach and remove the handle and slides to help balance your camera. It features a single 15mm rod bracket, two cold shoe mounts, and multiple 1/4"-20 and 3/8"-16 accessory threads.
8Sinn Cage for Sony a7S III/a7 IV with Top Handle Pro
SKU: 8-a7SIII C+8-THP
$258.00 Regular Price
$167.70Sale Price
    • Formfitting Camera Cage
    • Adjustable Top Handle
    • 19 x 1/4"-20 Accessory MountingThreads
    • ARRI-Style 3/8"-16 Anti-Twist
    • Maintains Access to Camera's Hot Shoe
    • Built-In Shoe Mount, Strap Slots
    • Front Threads for Optional Lens Adapter
  • 8Sinn Cage For Sony A7S III/A7 IV Specs
    Support Type
    Cage
    Grip Type
    None
    Camera Compatibility
    Sony a7 IV, Sony a7S III
    Cage, Top: 8 x 1/4"-20 Female Thread, 1 x Anti-Twist 3/8"-16 Female Thread
    Cage, Sides: 11 x 1/4"-20 Female Thread
    Camera Mounting
    1/4"-20 Male Screw
    Tripod Mounting
    Cage: 1/4"-20 Female Thread, 3/8"-16 Female Thread
    Cage: 1 x Cold Shoe
    None
    5.8 x 4.1 x 2.7" / 148 x 104 x 68 mm
    5.8 oz / 165 g
    8Sinn Top Handle Pro With NATO Rail (2.4") Specs
    Topside Handle
    Rotation
    No
    Built-In Controls
    None
    Attachment Method
    Attaches via Rail
    Rod Standard
    15 mm Single Rod
    Rod Ports
    1 x 15 mm Rod Port
    Multiple x 1/4"-20 Thread
    Multiple x 3/8"-16 Thread
    2 x Built-In Cold Shoe Slot
    None
    Rail Mounting
    1 x NATO Rail Clamp
    1 x NATO Rail That Attaches via 2 x Included 1/4"-20 Screw
    6.2 x 2.7 x 2.3" / 158 x 69 x 59 mm
    5.1 oz / 145 g
