8Sinn 8-DMCV2 Overview
The 8Sinn Director's Monitor Cage V2 allows you to mount up to a 7" monitor in the center for handheld use on set. Plus, there's a slot on the bottom center for stand-mounting it. It has a thumbwheel-adjustable post inserted in it, which can be screwed in or out for compatibility with different-sized stands.
Two side handles are adjustable forward and backward without any tools, and they're foam-padded and ergonomic for a comfortable grip. There's also a mounting plate on the rear with M3 mounting threads for select Gold mount and V-mount battery plates. Additionally, between this mounting plate and the platform where the monitor attaches, there's another platform with multiple 1/4"-20 threads where you can connect a transmitter. The transmitter would sit between the monitor and the battery plate, and the space is large enough for most transmitters.
The mounting platform for your monitor is padded for twist- and scratch-free attachment. A 1/4"-20 mounting screw is included for your monitor, and the mounting platform has a slot for the screw that allows some forward/backward adjustment.
8Sinn V-Mount Battery Plate
The V-Mount Battery Plate from 8Sinn is designed to allow V-mount batteries to be mounted on cameras without a back battery plate. It has multiple mounting holes for universal camera connection and a 50W D-Tap port which can provide power from the V-mount battery to accessories such as recorders, lights, and monitors.
* Can serve as an adapter for various accessories
* Standardized solution and fit for various camera models
* V-lock connection prevents the need for extra cabling
* Precise and secure lock onto the battery
8Sinn Director's Monitor Cage V2 Kit with V-Mount Battery Plate
SKU: 8-DMCV2 + 8-V-MBP
$239.00 Regular Price
$119.50Sale Price
    • Director's Monitor Cage V2
    • V-Mount Battery Plate
    • For Onboard Monitors up to 7"
    • Adjustable Foam-Padded Ergonomic Handles
  • 8Sinn Director's Monitor Cage V2 For Up To 7" Monitors Specs
    Monitor Mount: 1 x Included 1/4"-20 Male Screw
    Stand Mount: 1 x 5/8" Receiver
    Accessory Mount: Multiple x 1/4"-20 Female Thread, Multiple x M3 Female Thread
    Width: 14.5" / 37 cm
    Width: 11.6" / 29.5 cm (Folded)
    Height: 4.2" / 10.7 cm (Height)
    Height: 5.1" / 13 cm (Handles)
    1.17 lb / 530 g
    8Sinn V-Mount Battery Plate Specs
    Inputs/Outputs
    1 x D-Tap
    Plate Front / Battery Mount
    V-Mount
