8Sinn Single Handgrip Overview
No tools are necessary to mount this Dual Side Grip from 8Sinn on a camera rig, cage, or extension arm. The lightweight handgrip features an ARRI-style rosette that secures to your rig using a thumbscrew. The grip is molded from a lightweight composite plastic and is designed to be gripped on both sides or through the center opening. The rosette attachment is made of durable aluminum.
8Sinn Dual Side Grip
SKU: 8-DSG
$95.00 Regular Price
$52.25Sale Price
    • Double-Sided Grip Design
    • ARRI-Style Rosette
    • Secured by Thumbscrew
    • Can be Gripped on Either Side
    • Lightweight Design
    • Composite and Aluminum Construction
  • 8Sinn Single Handgrip Specs
    Ambidextrous Handgrip
    Attachment Method
    Attaches via Rosette
    None
    None
    1 x ARRI Rosette w/ M6 Thread
    Rail Mounting
    None
    Aluminum, Plastic
    5.7 x 2.8 x 1.8" / 14.5 x 7 x 4.6 cm
    5 oz / 143 g
