8Sinn 8-MINI-V-MOUNT-BP+8-15RMB Overview
Use this Mini V-Mount Quick Release Battery Plate and 15mm Rod Mount Bridge bundle from 8Sinn to mount your V-mount battery on your 15mm rod-mounted configuration. Four 1/4"-20 mounting grooves attach the plate to the bridge's 1/4"-20 threads, while the bridge's dual 15mm LWS rod ports attach it to your rig of choice.
8Sinn Mini V-Mount Quick Release Battery Plate
Attach a single V-mount battery to your camera cage or baseplate using this Mini V-Mount Quick Release Battery Plate from 8Sinn. The plate features a V-mount system with a quick release lever for efficient mounting and dismounting of your extra battery. Four 1/4" mounting grooves on the outside of the plate secure it to the side of your camera rig with separately available screws. Its aluminum construction creates a lightweight design.
8Sinn 15mm Rod Mount Bridge
Mount a shoulder support, baseplate, and/or accessories on your 15mm LWS rod system with the 15mm Rod Mount Bridge from 8Sinn. This rod bracket is constructed from durable aluminum and features six 1/4"-20 accessory threads and locking thumbscrews on each side.
8Sinn Mini V-Mount Quick Release Battery Plate and 15mm Rod Mount Bridge
SKU: 8-MINI-V-MOUNT-BP+8-15RMB
$84.00 Regular Price
$50.40Sale Price
    • Mount One V-Mount Battery
    • 15mm LWS Rod Mount Bridge
    • Four 1/4" Mounting Grooves
    • Six 1/4"-20 Accessory Threads
  • 8Sinn Mini V-Mount Quick Release Battery Plate Specs
    Physical
    1 x V-Mount
    4 x 1/4"-20 Groove
    Color
    Black
    Material of Construction
    3.1 x 2.9 x 0.5" / 79 x 73 x 12 mm
    3.1 oz / 87 g
    8Sinn 15mm Rod Mount Bridge Specs
    Rod Standard
    15 mm LWS
    Mounting Threads
    6 x 1/4"-20
    4.2 x 1 x 0.8" / 107 x 25 x 20 mm
    1.8 oz / 51 g
