8Sinn Single Handgrip Overview
Add a handgrip to your shoulder rig with this Side Arm with Dual Side Grip from 8Sinn. The side arm features three ARRI-style rosettes with an articulating joint in the middle, connected by a thumbscrew.
On one end of the arm, a rosette secures to your shoulder rig with a thumbscrew. On the other end, the handgrip attaches to the other rosette with a thumbscrew. The handgrip allows you to hold it on either side for a comfortable grip. The rosette joint on the arm allows you to rotate the joint 360° for just the right position. Pair it with an optional second arm and grip combination for a dual grip rig.
8Sinn Dual Side Grip
No tools are necessary to mount this Dual Side Grip from 8Sinn on a camera rig, cage, or extension arm. The lightweight handgrip features an ARRI-style rosette that secures to your rig using a thumbscrew. The grip is molded from a lightweight composite plastic and is designed to be gripped on both sides or through the center opening. The rosette attachment is made of durable aluminum.
8Sinn Side Arm for Shoulder Rigs
Add an extension arm for a handgrip or other accessories on your shoulder rig with this Side Arm from 8Sinn. The aluminum arm is made up of two sections, and each section features a rosette on either side. The sections connect using one set of rosettes and a thumbscrew, which creates a rotating joint.
One end attaches to your rig with a thumbscrew, and the rosette on the other end features a thread for attaching a handgrip or other rosette accessory. There are two 1/4"-20 threads on the longer section that allow you to attach additional accessories.
8Sinn Side Arm with Dual Side Grip for Shoulder Rigs
SKU: 8-SA-SR+DSG
$180.00 Regular Price
$99.00Sale Price
    • Articulating Side Arm
    • Double-Sided Grip Design
    • ARRI-Style Rosettes
    • Secured by Thumbscrews
    • 2 x 1/4"-20 Accessory Threads
    • Composite Grip, Aluminum Construction
  • 8Sinn Dual Side Grip Specs
    Ambidextrous Handgrip
    Attachment Method
    Attaches via Rosette
    None
    None
    1 x ARRI Rosette w/ M6 Thread
    Rail Mounting
    None
    Aluminum, Plastic
    5.7 x 2.8 x 1.8" / 14.5 x 7 x 4.6 cm
    5 oz / 143 g
    8Sinn Side Arm For Shoulder Rigs Specs
    Material of Construction
    3 x ARRI-Style Rosettes
    2 x Thumbscrews
    Accessory Mounting Threads
    2 x 1/4"-20
    Not Specified by Manufacturer
