8Sinn Top Handle Overview
The Top Handle Scorpio + ARRI NATO Rosette 28mm Mount + Safety NATO Rail 2.4" Bundle from 8Sinn can be attached directly to most cages with two included 1/4"-20 screws. The ARRI-standard rosette mount attaches to the NATO rail by quick release, and the Top Handle Scorpio secures to the rosette mount.
8Sinn Scorpio Top Handle
The Scorpio Top Handle from 8Sinn is made of CNC aluminum. The handle features 1/4"-20 and 3/8"-16 mounting holes, four cold shoes, and a 15mm rod mount.
8Sinn ARRI NATO Rosette 28mm Mount
Mounting adapter for Arri standard accessories like holders, top handles, etc. This product is a part of the quick-release system when mounted on separate or built-in Safety NATO Rail
8Sinn Safety NATO Rail (2.4")
The 8Sinn 2.4" Safety NATO Rail is a short-length NATO-standard rail that can be attached to camera cages and other camera supports. It attaches using two included 1/4"-20 screws, and it features a slotted design so that you can space out the screws as needed to match the spacing on your cage or other support. The NATO rail provides a quick release mounting solution with a safety pin for NATO-compatible top handles, monitor mounts, and other gear.
8Sinn Top Handle Scorpio + ARRI NATO Rosette 28mm Mount + Safety NATO Rail 2.4"
SKU: 8-THSV2+8-ANR28MMM+8-SNR60MM
$144.00 Regular Price
$86.40Sale Price
    • 1/4"-20 Attachment to Cages & Other Gear
    • Quick Release NATO Rail with Safety Pin
    • NATO Rail Mount ARRI Rosette
    • Rosette Mount Top Handle Scorpio
  • 8Sinn Scorpio Top Handle Specs
    Topside Handle
    Multiple x 1/4"-20 Thread
    Multiple x 3/8"-16 Thread
    5.7 x 2.8 x 1" / 14.5 x 7.1 x 2.5 cm
    7.7 oz / 218 g
    Package Weight
    0.8 lb
    Box Dimensions (LxWxH)
    9.2 x 6 x 3.2"
    8Sinn ARRI NATO Rosette 28mm Mount Specs
    Package Weight
    0.06 lb
    2.7 x 2.05 x 1"
    8Sinn Safety NATO Rail (2.4") Specs
    Material
    2.4 x 0.35 x 0.8" / 60 x 9 x 20 mm
    0.8 oz / 23 g
