8Sinn 8-NZ6Z7 C Overview
The 8Sinn Nikon Z6/Z7 Cage is a formfitting, 4-sided cage with the right side ergonomically designed with gentle edges to provide a comfortable grip. 1/4"-20 mounting threads all around and a shoe mount on the side allow you to securely attach accessories. There's also a slot on the side for an optional wrist strap. The cage does not interfere with any of the camera's buttons, ports, or slots. It is made from a single piece of aluminum and provides protection all around. Your camera secures to a 1/4"-20 tie-down screw that screws in from the bottom of the cage using an included Allen key.
*[B-Stock] 8Sinn Cage for Nikon Z6/Z7
SKU: 8-NZ6Z7 C
$135.00 Regular Price
$54.00Sale Price
    • Formfitting cage made from one piece of aluminum
    • Right side ergonomically designed with gentle edges to provide a comfortable grip
    • 1/4"-20 mounting threads
    • Shoe mount
    • Wrist strap slot
    • Leaves access to all camera buttons, ports, and slots
    • 1/4"-20 tie-down screw
  • 8Sinn 8-NZ6N7 C Specs
    Battery Plate Type
    No
    Top
    15x 1/4"-20 Female Thread
    Sides
    17x 1/4"-20 Female Thread
    Base
    22x 1/4"-20 Female Thread
    1x 3/8"-16 Female Thread
    Camera Mounting
    1/4"-20 Male Screw
    Tripod Mounting
    1/4"-20 Female Thread, 3/8"-16 Female Thread
    Top
    1x Cold Shoe
    No
    Cable Clamp
    No
    6 x 4.3 x 2.5" / 15.3 x 10.9 x 6.4 cm
    0.44 lb / 199 g
