8Sinn 8-NZ6Z7 C +THP Overview
The Cage for Nikon Z6 and Z7 with Top Handle Pro from 8Sinn bundles a camera cage designed for the Nikon Z6 and Z7 cameras with a Top Handle Pro. The kit is ideal for mounting a series of optional devices and accessories, such as a microphone, an on-camera monitor or light, and even a comfortable shoulder support.
8Sinn Cage for Nikon Z6, Z7
Protect your camera and enhance its accessory mounting possibilities with this Cage for Nikon Z6 and Z7 from 8Sinn. Encompassing style, protection, and versatility, this lightweight cage designed and form-fitted specifically for the Nikon Z6 and Z7 features multiple 1/4"-20 and M4 mounting points, a cold shoe mount, a 3/8"-16 mounting point at the top and one on the bottom, and an integrated camera strap holder. Its sturdy aluminum construction ensures rugged performance and extended durability.
8Sinn Top Handle Pro with NATO Rail (2.4")
The 8Sinn Pro Top Handle mounts easily on your camera cage using the included 2.4" NATO rail. The NATO rail mount makes it easy to attach and remove the handle and slides to help balance your camera. It features a single 15mm rod bracket, two cold shoe mounts, and multiple 1/4"-20 and 3/8"-16 accessory threads.
*[B-Stock] 8Sinn Cage for Nikon Z6/ Z7 with Top Handle Pro
SKU: 8-NZ6Z7 C +THP
$247.00 Regular Price
$74.10Sale Price
    • Form-Fitted for Nikon Z6/Z7
    • Top Handle Pro Included
    • Multiple 1/4"-20 and M4 Mounting Points
    • NATO Rail-Mount Top Handle
    • Camera Strap Holder
    • Aluminum Construction
  • 8Sinn 8-NZ6N7 C Specs
    Battery Plate Type
    No
    Top
    15x 1/4"-20 Female Thread
    Sides
    17x 1/4"-20 Female Thread
    Base
    22x 1/4"-20 Female Thread
    1x 3/8"-16 Female Thread
    Camera Mounting
    1/4"-20 Male Screw
    Tripod Mounting
    1/4"-20 Female Thread, 3/8"-16 Female Thread
    Top
    1x Cold Shoe
    No
    Cable Clamp
    No
    6 x 4.3 x 2.5" / 15.3 x 10.9 x 6.4 cm
    0.44 lb / 199 g
    8Sinn Top Handle Pro Specs
    Topside Handle
    Attachment Method
    Attaches via Rail
    Rod Standard
    15 mm Single Rod
    Multiplex 1/4"-20 Thread
    Multiplex 3/8"-16 Thread
    2x Built-In Cold Shoe Slot
    No
    Rail Mounting
    1x NATO Rail Clamp
    1x NATO Rail That Attaches via 2x Included 1/4"-20 Screw
    6.2 x 2.7 x 2.3" / 158 x 69 x 59 mm
    5.1 oz / 145 g
