8Sinn 8-NZ6Z7 C V2+THSV2 Overview
The Cage for Nikon Z6 and Z7 with Top Handle Scorpio V2 from 8Sinn bundles a camera cage designed for the Nikon Z6 and Z7 cameras with a Top Handle Scorpio, and an ARRI Rosette 28mm Mount. The kit is ideal for mounting a series of optional devices and accessories, such as a microphone, an on-camera monitor or light, and even a comfortable shoulder support.
8Sinn Cage for Nikon Z6, Z7
Protect your camera and enhance its accessory mounting possibilities with this Cage for Nikon Z6 and Z7 from 8Sinn. Encompassing style, protection, and versatility, this lightweight cage designed and form-fitted specifically for the Nikon Z6 and Z7 features multiple 1/4"-20 and M4 mounting points, a cold shoe mount, a 3/8"-16 mounting point at the top and one on the bottom, and an integrated camera strap holder. Its sturdy aluminum construction ensures rugged performance and extended durability.
8Sinn Scorpio Top Handle
The Scorpio Top Handle from 8Sinn is made of CNC aluminum. The handle features 1/4"-20 and 3/8"-16 mounting holes, four cold shoes, and a 15mm rod mount.
8Sinn ARRI Rosette 28mm Mount
The 8Sinn ARRI Rosette 28mm Mount is a standard-size ARRI rosette mount with an M6 thread in the center for attaching compatible handgrips and other accessories. It can be secured to camera cages and other supports that have two 1/4"-20 mounting threads. It secures with two included 1/4"-20 screws, and it features wide 1/4"-20 pass-through slots so you can set the screws at the required spacing to match the accessory you're attaching to.
*[B-Stock] 8Sinn Cage for Nikon Z6/ Z7 with Top Handle Scorpio V2
SKU: 8-NZ6Z7 C +THSV2
$247.00 Regular Price
$74.10Sale Price
    • Form-Fitted for Nikon Z6/Z7
    • Top Handle Scorpio Included
    • ARRI Rosette 28mm Mount Included
    • Multiple 1/4"-20 and M4 Mounting Points
    • 5 x Cold Shoe Mounts
    • M6 Center Thread on ARRI Rosette Mount
    • Camera Strap Holder
    • Aluminum Construction
  • 8Sinn 8-NZ6N7 C Specs
    Battery Plate Type
    No
    Top
    15x 1/4"-20 Female Thread
    Sides
    17x 1/4"-20 Female Thread
    Base
    22x 1/4"-20 Female Thread
    1x 3/8"-16 Female Thread
    Camera Mounting
    1/4"-20 Male Screw
    Tripod Mounting
    1/4"-20 Female Thread, 3/8"-16 Female Thread
    Top
    1x Cold Shoe
    No
    Cable Clamp
    No
    6 x 4.3 x 2.5" / 15.3 x 10.9 x 6.4 cm
    0.44 lb / 199 g
    8Sinn Scorpio Top Handle Specs
    Multiplex 1/4"-20 Thread
    Multiplex 3/8"-16 Thread
    5.7 x 2.8 x 1" / 14.5 x 7.1 x 2.5 cm
    7.7 oz / 218 g
    8Sinn ARRI Rosette 28mm Mount Specs
    Material of Construction
    Center Thread
    M6
    Rosette Diameter
    28 mm Standard
    1.7 x 0.3 x 1.1" / 44 x 8 x 28 mm
    0.67 oz / 19 g
