8Sinn Top Handle Overview
The 8Sinn Pro Top Handle mounts easily on your camera cage using the included 2.4" NATO rail. The NATO rail mount makes it easy to attach and remove the handle and slides to help balance your camera. It features a single 15mm rod bracket, two cold shoe mounts, and multiple 1/4"-20 and 3/8"-16 accessory threads.
*[B-Stock] 8Sinn Top Handle Pro with NATO Rail (2.4")
SKU: 8-THP
$109.00 Regular Price
$38.15Sale Price
    • For Cages with 1/4"-20 Thread Mounts
    • 2.4" NATO Rail, 1 x 15mm Rod Bracket
    • 2 x Cold Shoe Mounts
    • 1/4"-20 & 3/8"-16 Accessory Threads
  • 8Sinn Top Handle Specs
    Topside Handle
    Rotation
    No
    Built-In Controls
    None
    Attachment Method
    Attaches via Rail
    Rod Standard
    15 mm Single Rod
    Rod Ports
    1 x 15 mm Rod Port
    Multiple x 1/4"-20 Thread
    Multiple x 3/8"-16 Thread
    2 x Built-In Cold Shoe Slot
    None
    Rail Mounting
    1 x NATO Rail Clamp
    1 x NATO Rail That Attaches via 2 x Included 1/4"-20 Screw
    6.2 x 2.7 x 2.3" / 158 x 69 x 59 mm
    5.1 oz / 145 g
