BRIDGE EX DADA-B - Overview
The Digital Forecast BRIDGE EX DADA is an AES/EBU digital audio distribution amplifier module offering a single input and eight reclocked ouput configuration. This module has signal and sample rate detection accepting 32kHz, 44.1kHz, 48kHz sampling rates. The BRIDGE EX DADA has a built-in reclocking and equalizing circuit, with automatic equalization sending signals up to 600m at 70 ohm or 300m at 110 ohms or less.
Specifications:
- AES/EBU Digital Audio Input
- Input Number: 1
- Input Standard: SMPTE276M, AES3id-1995
- Coupling: Transformer coupled
- Connector: 110 Ω terminal block
- Signal level: 2~7Vp-p(110 Ω)
- Input Return Loss: >25dB at 0.1 to 6MHz (75Ω)
- Sample Rate: 32kHz, 44.1kHz, 48kHz
AES/EBU Digital Audio Output - Output Number: 8
- Output Standard: SMPTE276M, AES3id-1995
- Coupling: Transformer coupled(110Ω)
- Connector: 110Ω terminal block
Electrical - Voltage: +12V DC
- Power Dissipation: < 3W
- Temperature: 0 ~ 40°C
- Signal level: 2~7Vp-p(110Ω)l
- Jitter: < 5ns
- Rise & Fall Tim: 30-40ns(75Ω), 5-30ns(110Ω)
Warranty:
- 2 Years
BRIDGE EX DADA-B AES/EBU Digital Audio Distribution Amplifier Module
- Supports SMPTE276M, AES3id-1995
- Up to 8 Reclocked outputs
- 110 Ohm Input/Output
- Input Present and sample rate auto detect
- Automatic equalization up to 300m (110 Ohm)
- Accepts 32kHz, 44.1kHz, 48kHz sampling rate
- Supports Auto/Manual cable equalization
