X_TS PACK V3 - Overview
The Digital Forecast X_TS Pack V3 is a Compact Multi-Platform Signal Converter with Measurement and Test Pattern Generation. The X_TS can be effectively used in installation and maintenance of video and audio signals. The X_TS is a handy but powerful series that enables you to conveniently check a variety of signals through a built-in 5 inch LCD touch screen. You can choose from video display, SDI jitter and Cable conditions.
  • Specifications:
    • Operating Environment
    • Power Level: +12VDC
    • Power Consumption: 13 Watts (Maximum 15 Watts)
    • Operating Temperature: 32° to 158°F (0° to 70°C)
    • Humidity: 0 to 95% RH, Non-condensing
    • Case Dimensions: 11.92 x 10.51 x 4.57" (303 x 267 x 116mm)
    • Total Weight: 5.29Lbs (2.4kg)
      Video Standards
    • Supports HDMI v1.3
    • Supports VGA, Comp, CVBS format
    • Supports multi-rate SDI formats
    • SMPTE 125M: NTSC (480i 59.94), PAL (576i 50)
    • SMPTE 296M: 720p (60/59.94/50)
    • SMPTE-274M: 1080i (60/59.94/50)
    • SMPTE-292M: 1080p (30/29.97/25/24/23.98)
    • SMPTE-424M: 1080p (60/59.94/50) 3G
      LCD Specification
    • Size: 5"
    • Resolution: 800 x 480
    • Pixel Area WxH: 0.135 x 0.132mm
    • Display Area WxH: 108 x 64.8mm
  • Item Includes:
    • 1x X_TS main body
    • 1x Side bumper set
    • 1x Power adapter
    • 1x Sony battery plate
    • 1x Component to VGA adapter
    • 1x Stereo RCA to 3.5mm adapter
    • 1x HDMI cable
    • 1x BNC SDI cable
    • 1x Hard shell case
Bridge X-TS PACK V3 Video and Audio Troubleshooter and Cross Converter Hard Case
SKU: X-TS PACK V3
$1,424.00Price
    • Digital to Audio / Audio to Digital Converter
    • Up/Down/Cross/Scan converter
    • Standard Video / Audio signal supported (SDI, HDMI, CVBS, COMPONENT, VGA, DVI,Analog Audio, AES / EBU)
    • Analog Audio Mux / DeMux
    • Jitter Measurement for SDI signal (720p, 1080i, 1080p)
    • Test Pattern Generator : 8 types provided
    • SDI signal integrity check (Loss, TSR, CRC, Line number)
    • HDMI signal integrity check (Loss, Resolution, HDCP)
    • Audio Level Monitoring (up to 8 channels)
    • 5" Touch Screen LCD (800x480)
    • Includes a Sony battery mounting plate
