X_TS V3 - Overview
The Digital Forecast X_TS V3 is a Compact Multi-Platform Signal Converter with Measurement and Test Pattern Generation. The X_TS series can be effectively used in installation and maintenance of video and audio signals. The X_TS is a handy but powerful series that enables you to conveniently check a variety of signals through a built-in 5 inch LCD touch screen. You can choose from video display, SDI jitter and Cable conditions.
  • Specifications:
  • Operating Environment
  • Power Level: +12VDC
  • Power Consumption: 13 Watts (Maximum 15 Watts)
  • Operating Temperature: 32° to 158°F (0° to 70°C)
  • Humidity: 0 to 95% RH, Non-condensing
    Video Standards
  • Supports HDMI v1.3
  • Supports VGA, Comp, CVBS format
  • Supports multi-rate SDI formats
  • SMPTE 125M: NTSC (480i 59.94), PAL (576i 50)
  • SMPTE 296M: 720p (60/59.94/50)
  • SMPTE-274M: 1080i (60/59.94/50)
  • SMPTE-292M: 1080p (30/29.97/25/24/23.98)
  • SMPTE-424M: 1080p (60/59.94/50) 3G
    LCD Specification
  • Size: 5"
  • Resolution: 800 x 480
  • Pixel Area WxH: 0.135 x 0.132mm
  • Display Area WxH: 108 x 64.8mm
  • Item Includes:
    • 1x X_TS Main Body
    • 1x Adapter
    • 1x VGA to Component Jack
    • 1x Analog Audio Jack
Bridge X-TS V3 Video and Audio Troubleshooter and Cross Convert
SKU: X-TS V3
$1,234.00Price
    • Digital to Audio / Audio to Digital Converter
    • Up/Down/Cross/Scan converter
    • Standard Video / Audio signal supported
    • (SDI, HDMI, CVBS, COMPONENT, VGA, DVI,Analog Audio, AES / EBU)
    • Analog Audio Mux / DeMux
    • Jitter Measurement for SDI signal (720p, 1080i, 1080p)
    • Test Pattern Generator : 8 types provided
    • SDI signal integrity check (Loss, TSR, CRC, Line number)
    • HDMI signal integrity check (Loss, Resolution, HDCP)
    • Audio Level Monitoring (up to 8 channels)
    • 5" Touch Screen LCD (800x480)
    • Battery Mounting Plate for Sony and Canon type (optional)
