8Sinn Top Handle Overview
The Basic Top Handle from 8Sinn is designed for use with the 8Sinn cages. Featuring an ergonomic design and lightweight construction, the handle is equipped with 1/4"-20 and 3/8"-16 threaded mounting points and two cold shoes. The diameter of the internal space in the handle creates a mounting place for 15mm rods.
8Sinn Basic Top Handle
SKU: 8-THB
$49.00 Regular Price
$19.60Sale Price
    • For use with 8Sinn Cages
    • 1/4" and 3/8" Threaded Mounting Points
    • Two Cold Shoes at Front
    • Can Hold 15mm Rods
  • 8Sinn Top Handle Specs
    Topside Handle
    Rotation
    No
    Attachment Method
    Attaches via 2 x Included M4 Screw
    Compatibility
    Attaches onto Mirrorless Support
    Rod Standard
    15 mm Single Rod
    Rod Ports
    1 x 15 mm Rod Port
    Multiple x 1/4"-20 Thread
    Multiple x 3/8"-16 Thread
    1 x Built-In Cold Shoe Slot
    None
    Rail Mounting
    None
    6.3 x 2.6 x 2.2" / 15.9 x 6.6 x 5.6 cm
    4.2 oz / 118 g
