Bumble Bee 14.4V, 145Wh Li-Ion Battery (Gold Mount / Micro-Size)
The GENTREE Bumble Bee Series Battery is designed to deliver reliable power for cameras and professional video accessories. With an ultra-compact size, it’s suitable for the handheld camera, gimbal application, and it’s carry-friendly battery.
This robust battery features two D-Tap ports and a USB-C port with PD 65W support, allowing for both charging and discharging.
GENTREE batteries are uniquely designed to be shock-resistant and short-circuit proof, ensuring durability and safety. They also feature a cable-free PCB design, which minimizes impedance, ensuring optimal power efficiency and performance at extreme temperatures.
A 10-LED power gauge helps ensure timely battery replacements by clearly displaying the remaining charge.
FEATURES
US Military Drop-Test Passed
Short-out Proof
Lowest Impedance (cable-free PCB)
Mount / Series TypeGold Mount / Micro-Size
Capacity (Wh)145 Wh
Amp-Hours10.2 Ah
Output Voltage14.4 VDC
Accessory Port1 x D-Tap
1 x USB C Port (PD 65W/Charge & Discharge)
Maximum Load (D-Tap Port)12 A ( D-Tap )
USB C PortPD+PPS 65W Charge & Discharge
Charging Voltage16.8 VDC
Discharging Temperature50 to 104°F / 10 to 40°C
Dimensions (W x H x D)2.91 x 4.09 x 3.22" / 74 x 104 x 82 mm
Weight1.72 lb / 780 g
GENTREE Bumble Bee 14.4V, 145Wh Micro-Size Li-Ion Gold Mount
SKU: G-B50/145W 12AC G
$335.00Price
    • 1 x USB C Port / PD65W (Charge & Discharge Supported)
    • 14.4V 145Wh Li-Ion Gold Mount Battery
    • Support up to Total 12A Draw
    • 12A Max. Draw from a D-Tap Port
    • 1 x D-Tap Port
    • GENTREE Bumble Bee 14.4V, 145Wh Li-Ion Gold mount Battery (12A)
