Postium Korea PRM-902Q Overview
The LCD 4RU Multi-Channel Rack Monitor from BON features two 9” 960 x 540 LED backlit LCD panels with 90° tilt range. It provides front panel individual control for brightness, contrast, chroma, SDI A/B select, analog, aspect select (16:9, 4:3), H/V delay, embedded audio level, scan (over, zero, 1:1), marker (user selectable), blue/mono, waveform (Y Cb Cr), and vectorscope. Inputs include two HD/SD-SDI with active loop, component, S-Video, RGB, RJ45 remote control, and a serial firmware upgrade port. Outputs include one SDI and one stereo mini audio out.
  • Multi-format support (480i, 576i, 720p, 1080i, 1080p, 1080psf, 2K)
  • 2x HD/SD-SDI inputs (Auto Detecting/Switching) with Active Loop Through
  • Two HD 9” 960 x 540 resolution, 16.7 MP wide screens
  • Analog inputs including, composite, S-Video, YPbPr, and RGB
  • 4RU standard EIA 19” rack
  • Closed caption CEA-608/708, AFD, and H/V delay mode
  • Analog stereo audio out phone jack
  • Internal left & right speakers (2 x 1W)
  • Blue Only & Monochrome
  • Markers & safety areas including user defined markers
  • Source ID function (user defined in OSD function)
  • 16-channel embedded audio level meter
  • Timecode display (VITC & LTC)
  • Selectable full & small size, waveform (Y Cb Cr), and vectorscope for SDI
  • Postium Korea Dual 9" LCD 4RU Multi-Channel Rack Monitor
  • DC Power Adapter
SKU: PRM-902Q
$2,946.95Price
