RS 8X4 SDI - Overview
The Digital Forecast Bridge RS Series includes the RS 8x4 HD-SDI Routing Switcher. The RS 8x4 HD-SDI features 8x4 SDI video inputs and outputs and (1) one HDMI output, supporting SD, HD and 3G SDI sources. APC network control, reclocked SDI out, and vertical synchronization of the source signal are provided features of this switcher. Additionally, RCP, Preset Set and a button lock function add convience for the user. Auto cable equalizing is a key function (HD grade: compensate for up to 100m/328ft, SD grade: up to 300m/984ft of Belden 1694 cable).
Specifications:
- Connections
- SDI Video Input: 8x SD/HD-SDI, 3Gb/s SDI and ASI
- SDI Video Output: 4x SD/HD-SDI, 3Gb/s SDI and ASI with SDI re-clocking
- HDMI OUTPUT: 1x HDMI
- Remote Control: RS-422 (RJ45)
- Reference Input: 1x BNC B.B , TRI
- NET: TCP/IP (RJ45)
Standards - SD Format Support: NTSC (480i59.94) and PAL (576i50)
- HD Format Support: 720p(60/59.94/50), 1080i(60/59.94/50), 1080P(30/29.97/25/24/23.98), 1080p(60/59.94)3G
- SDI Compliance: SMPTE 259M, SMPTE 292M, SMPTE 296M, SMPTE 310M, SMPTE 425M-A, SMPTE 425M-B
- SDI Video Sampling: 4:2:2 and 4:4:4
- SDI Video Rates: SDI video connections are switchable between standard definition, high definition and 2K. SDI switches between 270 Mb/s standard definition SDI, 1.5 Gb/s HD-SDI and 3 Gb/s HD SDI
- SDI Auto Switching: Automatically selects between SD-SDI, HD-SDI, 3 Gb/s SDI and DVB-ASI on each input so that each input can be running a different television standard
Physical - Dimensions: WxHxD 13 x 1.5 x 4.3" (330 x 40 x 110 mm)
- Weight: 3.3 lb (1.55 kg)
- Power: 12V DC, 3.33A
Warranty:
- 2 Years
Digital Forecast RS 8X4 3G/HD/SD SDI Matrix Routing Switcher
- Support SMPTE 292M, SMPTE 344M, SMPTE 259M, SMPTE 424M
- Re-clocking
- Multi-Rate SDI (143M, 177M, 270M, 340M, 540M, 1.485G, 1.485/1.001G, 2.97G)
- 3G/HD/SD-SDI 8 in x 4 out
- 1 HDMI Output
- Auto equalizing (HD grade: compensate for up to 100m, SD: up to 300m of Belden 1694 Cable )
- RS-422 deck control ports (RJ45)
- DC12V 3.33A Power supply included
