The robust 14.4V, 290Wh, 15A Li-Ion Battery from GENTREE provides power for your Gold mount camera or pro video accessory. The 15A battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed to be both shock- and short-proof, and each features a wireless design that dissipates heat. 10-Step LED remaining-power display aids in timely battery changes.
  • SPECS
    Mount / Series TypeGold Mount
    Capacity (Wh)290 Wh
    Amp-Hours20 Ah
    Output Voltage14.4 VDC
    Amps Load15 A
    Accessory Port2 x D-Tap Ports
    1 x USB Type-A Port
    Minimum Load (Accessory Port)
    144 W, 12A (D-Tap)
    180W, 15A (Terminal)
    USB Output5 V, 2.3 A
    Charging Voltage16.8 VDC
    Charging Temperature50 to 86°F / 10 to 30°C (Recommended)
    Discharging Temperature50 to 104°F / 10 to 40°C (Recommended)
    Dimensions (W x H x D)5.75 x 3.82 x 3.07" / 146 x 97 x 78 mm
    Weight3.34 lb / 1520 g
GENTREE 290Wh / 20Ah Li-Ion Gold Mount Battery (15A Max. Discharge Rate)
SKU: G-B100/290W 15A G
$479.00Price
    • 14.4V 290Wh Li-Ion Gold Mount Battery
    • Supports up to Total 15A Draw
    • 12A Draw at D-Tap Port
    • Shock-proof built-in design
    • 2 x D-Tap Ports
    • 1 x USB Port
    • 10-Step Power Remaining LED
    • Compact Vertical Design
  • GENTREE G-B100 14.4V, 290Wh Li-Ion GOLD-Mount Battery (15A)
