The robust 14.4V, 290Wh, 12A Li-Ion Battery from GENTREE provides power for your Gold mount camera or pro video accessory. The 12A battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed to be both shock- and short-proof, and each features a wireless design that dissipates heat. 10-Step LED remaining-power display aids in timely battery changes.
Mount / Series Type Gold Mount Chemistry Lithium-Ion Capacity (Wh) 290 Wh Amp-Hours 20 Ah Output Voltage 14.4 VDC Amps Load 12 A Accessory Port 2 x D-Tap Ports
1 x USB Type-A PortMinimum Load (Accessory Port) 84W, 7A (D-Tap)
144W, 12A (Terminal)
USB Output 5 V, 2.3 A Charging Voltage 16.8 VDC Charging Temperature 50 to 86°F / 10 to 30°C (Recommended) Discharging Temperature 50 to 104°F / 10 to 40°C (Recommended) Dimensions (W x H x D) 5.75 x 3.82 x 3.07" / 146 x 97 x 78 mm Weight 3.34 lb / 1520 g
GENTREE 290Wh / 20Ah Li-Ion Gold Mount Battery
- 14.4V 290Wh Li-Ion Gold Mount Battery
- Supports up to 12A Total Draw
- Shock-proof built-in design
- No-Wire PCB design
- 2 x D-Tap Ports
- 1 x USB Port
- 10-Step Power Remaining LED
- Compact Vertical Design
GENTREE G-B100 14.4V, 290Wh Li-Ion GOLD-Mount Battery
