The robust G-B100 14.4V, 98Wh, 12A Li-Ion Battery from GEN ENERGY provides power for your Gold mount camera or pro video accessory. The 12A G-B100 battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed to be both shock- and short-proof, and each features a wireless design that dissipates heat. 10-Step LED remaining-power display aids in timely battery changes.
  • SPEC
    Mount / Series TypeGold Mount
    Capacity (Wh)98 Wh
    Amp-Hours6.8 Ah
    Output Voltage14.4 VDC
    Amps Load12 A
    Accessory Port2 x D-Tap Ports
    1 x USB Type-A Port
    Minimum Load (Accessory Port)
    D-Tap : 7A, 84W
    Terminal : 12A, 144W
    USB Output5 V, 2.3 A
    Charging Voltage16.8 VDC
    Charging Temperature50 to 86°F / 10 to 30°C (Recommended)
    Discharging Temperature50 to 104°F / 10 to 40°C (Recommended)
    Dimensions (W x H x D)5.75 x 3.82 x 1.54" / 146 x 97 x 39 mm
    Weight1.36 lb / 620 g
GENTREE 98Wh / 6.8Ah Li-Ion Gold Mount Battery
SKU: G-B100/98W G
$243.00Price
    • Supports up to 12A Total Draw
    • Shock-proof built-in design
    • 2 x D-Tap Ports
    • 1 x USB Port
    • 10-Step LED Power Remaining Guage
    • Compact Vertical Design
    • GENTREE G-B100 14.4V, 98Wh Li-Ion Battery (Gold-Mount)
