48V LED light ON-LOCATION power solution for ARRI Skypanel S60, S120 and Orbiter, Aputure 600D, Creamsource Vortex8, FiilexLED Q5,Q8, Nanlite Forza etc...
CUBE BANK M2 power distributer requires a pair of MONSTER batteries, G-B100/390W 26A (14.4V).
This two-batteries power solution can draw maximum 650W. It operate 48V light sources independently from an AC power source.
* Required Battery
  A Pair of G-B100/390W 26A (recommended) either
* Application LED & Run time w/ G-B100/390W 26A (at 100% full brightness)
  Creamsource Vortex8 : 1 hour
  Arri Orbitor : 2 hours
  Arri Skypanel S60 : 1 hour 40mins
  Aputure 300d II : 2 hours 20 mins
  Aputure 600d : 50 mins
*[ B-Stock ] GENTREE CUBE BANK Mark II Power Distributor for 48V LED Lights
SKU: G-PB48 M2
$895.00 Regular Price
$671.25Sale Price
    • Power distributor designed with GENTREE’s advance PCB, firmware and chipset.
    • Max output 650W (48V, 13.5A.) when in use of MONSTER battery (G-B100/390W 26A)
    • Max output 500W (48V, 10A.) when in use of G-B100/290W 22A battery
    • Compact and light enough to mount and carry.
