The robust G-B100 14.4V, 160Wh Li-Ion Batteryfrom GENTREE provides power for your V-mount camera or pro-video accessory. The 11Ah G-100 battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed to be both shock- and short-proof, and feature a wireless design that dissipates heat. A 10-LED gauge remaining-power display aids in timely battery changes.
GENTREE 160Wh / 11Ah Li-Ion V- Mount Battery
SKU: G-B100/160W
$343.00Price
    • 14.4V 160Wh Li-Ion V-Mount Battery
    • Supports up to 12A Total Draw
    • Shock-proof built-in design
    • 2 x D-Tap Accessory Outputs
    • 1 x USB Port
    • 10-LED Power Gauge
    • Compact Vertical Design
    • GENTREE G-B100 14.4V, 160Wh Li-Ion Battery (V-Mount)
