Basic kit composed of :
1x PENTA1200
4x G-B100/390W 26A
1x G-C100 3.5A
1x 1x Case w/Insert form
48V LED light ON-LOCATION power solution for Aputure 1200, 600 series lights, Nanlux 1200 series and 900C, Creamsource Vortex8 & 4, Skypanel X, S60, S120 and Orbiter, Fiilex Q10 etc...
G-PENTA1200 power distributer requires four of MONSTER batteries (G-B100/390W 26A 14.4V).
This four-batteries power solution can draw maximum 1344W. It operate 48V light sources independently from an AC power source.
* Run time at 100% full brightness in use of four MONSTER batteries (390Wh, 26A, 14.4V)
APUTURE 1200D50M Min.
NANLUX 1200B1H 5M Min.
NANLUX 900B1H 25M Min.
ARRI SKYPANEL X1H 35M Min.
ARRI ORBITER2H 50M Min.
ARRI SKYPANEL S603H 20M Min.
Aputure 600D or Nova600C1H 40M Min.
Creamsource Vortex 82H 10M Min.
Fiilex Q101H 20M Min.
Connector
Two 3-pin XLR output (720W Max. ea)
One 28A output (1344W Max.)
Power DC output48V , 28A regulated
Battery
Output
14.4V 26A (minimum. 312W)
Battery G-B100/390W 26A ( 4pcs required )
Weight3.7Kg (8.2 lbs) (without batteries)
Dimension217 x 154.8 x 92 mm (8.54 x 6.09 x 3.62" )
Operating temp.-10 ~ +45 °C recommended
GENTREE Monster1200 Kit (w/ 3.5A Quad Charger)
SKU: M1200K_3.5A
$5,945.00Price
    • Power distributor designed with GENTREE’s advance PCB, firmware and chipset.
    • Max output 1344W (48V, 28A.) when in use of MONSTER battery (G-B100/390W 26A)
    • Compact and light enough to mount and carry.
