HD&P CFOS 4K+S_4CH Overview
HD&P’s CFOS 4K+S_4CH System transforms cinema cameras into broadcast-ready cameras, enabling the transmission of power, video, intercom, tally, data, genlock, and other critical functions over long distances using SMPTE fiber optic cables. This advanced system is designed to meet the demands of 4K Cinema cameras and 4K camcorders, ensuring seamless integration into broadcast environments.
The Camera Adapter (CFOS 4K+S CA) easily attaches to the camera’s battery mount, converting it for broadcast use. The CFOS 4K+S_4CH configuration controls four cameras simultaneously, offering a powerful and flexible solution for professional broadcasting needs.
Base Station (CFOS 4K+S BS)
1. Configures up to 4 cameras
2. Moduler slots for easy addition up to 4 cameras
3. RCP data support (RS422)
4. 3 ports of 12G SDI output and 1 port of downstream (3G/HD SDI) output each camera
5. Support for common PGM return video input and loop out
6. Support for per-channel AUX video input (3G/HD-SDI)
7. Genlock signal input and Loop out support (Tri-level & BB level)
8. Intercom support (volume control and two inputs and outputs) (supported with optional internal intercom board)
9. Built-in port for external intercom equipment interworking or additional CFOS intercom interworking equipment support (2 -wire or 4-wire selectable - supported with optional internal intercom board)
10. 100 Mbps Ethernet support
11. One optical TX/RX support (ST/PC) on each camera
12. Built-in tally signal integration port
13. Built-in independent electrical safety breakers per camera
14. Optical signal power verification LED indication
HD&P SMPTE Fiber 4K Camera Transmission System - 4CH Camera
Camera Adapter: CFOS 4K+S CA
Base Station : CFOS 4K+S BS (Base Station : 3RU chassis + 4 x BS cards)
Camera Adapter Connection Cable (CA ~ Camera) BNC cable, RCP (LAN() cable,
Return Switch Connection Cable (CA ~ Camera Lens)
CFOS 4K+ Base Station Connection Cable (BS ~ Switcher/ RCP) Tally interface cable, Remote cable, AC power cable
Viewfinder monitor (Optional)
RCP (HDRC-17A) (Optional)
FEATURES
- Camera video : 12G-SDI
- Return video #1 3G / HD-SDI
- Return video #2 3G / HD-SDI
- Remote Control : RS422 / 232
- Tally Signal : Dry / Wet contact
- Genlock Signal : Black Burst / Tri-level sync
- IntercomSsignal : 4-wire / 2-wire
- Viewfinder : 3G/HD-SDI Camera, Return #1/2 selection, Analog Video
Tally, DC 12V - Local Power : DC 12V Input
- Power for camera : 15V
- Power : Hybrid optical cable (DC 48V)
Local power (DC 12V)
