Matrix Light ML-115R Overview
The ML-115R LED Light DSLR Camera Kit from Matrix Light includes an ML-115R LED light module, ML-DF3 diffuser, ML-SL10/AT1 C-type slide / attachment, ML-PC1 power cable, ML-BA12 Li-ion battery, and an ML-CHG1 battery charger. The LED light module is designed to be used for Virtual Reality 360° shooting, high-speed camera shooting, digital microscopes, chroma key lighting, and IR ray lighting. It features brightness and color temperature controllers where brightness can be controlled in 10% increments from 150 lumens to 2200 lumens, and color temperature can be controlled in 11 steps (in 240K increments) from 3200K to 5800K. With brightness and color temperature LED indicators on the back side, it allows the user to check the current brightness and color temperature. The Turbo mode supports up to 2200 lumens of brightness, equivalent to a 220W light bulb.
Using adaptable accessories, the ML-115R light module is suitable for electronic news gathering cameras, digital single-lens reflex cameras, and action cameras. It also has a USB communication port that allows simultaneous control of multiple units, making it useful for virtual reality / 360° shooting. The ML-BA12 Li-ion battery is compatible with ML-80, ML-7, ML-9, and ML-115R LED lights. Weighing 13.3 oz, it features a compact and lightweight design.
  • Designed to fit most macro lens systems
  • Can be used with industrial camera devices
  • Matrix Light ML-115R LED Light DSLR Camera Kit
  • Matrix Light ML-115R LED Ring Light Module
  • ML-DF3 Diffuser
  • ML-SL10/AT1 C-Type Slide / Attachment
  • ML-PC1 Power Cable
  • ML-BA12 Li-Ion Battery
  • ML-CHG1 Battery Charger
SKU: ML-115R DSLR KIT
$1,560.00Price
