Matrix Light ML-115R Overview
The ML-115R LED Ring Light Module from Matrix Light is designed to be used for virtual reality / 360° shooting, high-speed camera shooting, digital microscopes, chroma key lighting, and IR lighting. It features brightness and color temperature controllers where brightness can be controlled in 10% increments from 150 lumens to 2200 lumens, and color temperature can be controlled in 11 steps (in 240K increments) from 3200K to 5800K. With brightness and color temperature LED indicators on the back side, it allows the user to check the current brightness and color temperature. Turbo mode supports up to 2200 lumens of brightness, equivalent to a 220W light bulb.
Using adaptable accessories, the ML-115R light module is suitable for electronic news gathering cameras, digital single-lens reflex cameras, and action cameras. It also has a USB communication port that allows simultaneous control of multiple units, making it useful for virtual reality / 360° shooting.
  • Designed to fit most macro lens systems
  • Suitable lighting source for ENG and DSLR cameras, macro shooting
  • Can be used with industrial camera devices
  • Matrix Light ML-115R LED Ring Light Module
Not in the Box
  • Power Cables (Not Included)
SKU: MFR #ML-115R
$1,270.00Price
