Matrix Light ML-9 Overview
The ML-9 LED Light ENG Camera Kit from Matrix Lightincludes ML-9 LED Light Module, ML-DF2 Diffuser, ML-PT2 D-Tap Power Cable, ML-LB3 Ball Head Bracket, and ML-MSC1 Shoe Converter (Male to Female).
The ML-9 module features three built-in memory buttons that allow you to store your most frequently used brightness and color temperature settings. The dual indicators display current brightness and color temperature. With precision dimming and coloring controllers, the ML-9 allows the user to adjust the brightness and color temperature. Turbo mode supports up to 2200 lumens of brightness, equivalent to a 220W light bulb.
  • Matrix Light ML-9 LED Light ENG Camera Kit
  • Matrix Light ML-9 LED Light Module
  • ML-DF2 Diffuser
  • ML-PT2 D-Tap Power Cable
  • ML-LB3 Light Bracket (Ball Head)
  • ML-MSC1 Shoe Converter (Male to Female)
SKU: ML-9 ENG KIT
$1,050.00Price
