Matrix Light ML-9 Overview
The ML-9 LED Light Module from Matrix Light features three built-in memory buttons that allow you to store your most frequently used brightness and color temperature settings. The dual indicators display current brightness and color temperature. With precision dimming and coloring controllers, the ML-9 allows the user to adjust the brightness and color temperature. Turbo mode supports up to 2200 lumens of brightness, equivalent to a 220W light bulb.
Matrix Light ML-9 LED Light Module
Limited 1-Year Manufacturer Warranty
Specifications
▪ Type
Current regulated power LED light
▪ Light projection range
0.6 ~ 6M (Effective light projection range)
(depends on shutter speed, aperture levels, and gain control)
▪ Light projection angle
Horizontal :  110 ˚ vertical: 90 ˚
▪ Color Temperature
3200K~5800K (240K/1Step)
▪ Brightness
10% ~ 100% (230lm/1Step)
▪ Luminance Flux
1,100lm MAX (in Normal Mode)
2,200lm MAX (in Turbo Mode)
▪ Illuminance in 1M distance
1,100lux MAX (in Normal Mode)
2,200lux MAX (in Turbo Mode)
▪ Power supply
12V DC
▪ Current consumption
Normal mode: 1.5A/18W(Max)
Turbo mode :  3A/36W(Max)
▪ Luminance efficiency
66lm/W
▪ Battery
12V DC / 5,200mA (Li‐ion)
▪ Battery running time
2h 30min (Maximum Brightness in Normal Mode)
1h 15min (Maximum Brightness in Turbo Mode)
SKU: MFR #ML-9
$900.00Price
