Run your V-mount camera or pro video accessory on the G-B100 14.4V, 390Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its gold mount connection, this robust battery has a capacity of 27.2Ah and supports high-current draws up to 15A.
Mount / Series Type Gold Mount Chemistry Lithium-Ion Capacity (Wh) 390 Wh Amp-Hours 27.2 Ah Output Voltage 14.4 VDC Min. Discharge Power 180 W, 15 A Accessory Port 2 x D-Tap Ports
1 x USB C Port / PD65W Charge & DischargeMax. Discharge (D-Tap Port) 144 W, 12 A (D-Tap) USB C Port PD+PPS 65W Charge & Discharge Charging Voltage 16.8 VDC Storage Temperature -4 to 104°F / -20 to 40°C Charging Temperature 50 to 86°F / 10 to 30°C Discharging Temperature -4 to 122°F / -20 to 50°C Dimensions (W x H x D) 5.8 x 3.8 x 3.8" / 146.0 x 97.0 x 97.0 mm Weight 4.5 lb / 2040 g
OLED Display - GENTREE 390Wh Li-Ion Gold Mount Battery (15A Max. Discharge)
- OLED Display on front
- OLED information
✔ Temperature - 1 x USB C Port / PD65W (Charge & Discharge supported)
- 14.4V 390Wh Li-Ion Gold Mount Battery
- Support up to Total 15A Draw
- 12A Draw from a D-Tap Port
- No-Wire PCB design
- 2 x D-Tap Accessory Ports
GENTREE G-B100 14.4V, 390Wh OLED Li-Ion Gold Mount Battery (15A)
