Bumble Bee 14.4V, 98Wh Life Cycle Count Li-Ion Battery (V-Mount / Micro-Size)
The GENTREE Bumble Bee Series Battery is designed to deliver reliable power for cameras and professional video accessories. With an ultra-compact size, it’s suitable for the handheld camera, gimbal application, and it’s carry-friendly battery.
This robust battery features  D-Tap port and a USB-C port with PD 65W support, allowing for both charging and discharging.
GENTREE batteries are uniquely designed to be shock-resistant and short-circuit proof, ensuring durability and safety. They also feature a cable-free PCB design, which minimizes impedance, ensuring optimal power efficiency and performance at extreme temperatures.
The Built-in OLED display provides real-time information of cell cycle count, remaining battery time, voltage, current, and temperature.
The cell life cycle counting feature enables efficient tracking and management of the battery's condition, improving the maintenance process and extending the overall lifespan of the battery.
Mount / Series TypeV-Mount / Micro-Size
Capacity (Wh)98 Wh
Amp-Hours6.8 Ah
Output Voltage14.4 VDC
Accessory Port1 x D-Tap
1 x USB C Port (PD 65W/Charge & Discharge)
Maximum Load (D-Tap Port)12 A ( D-Tap )
USB C PortPD+PPS 65W Charge & Discharge
Charging Voltage16.8 VDC
Discharging Temperature50 to 104°F / 10 to 40°C
Dimensions (W x H x D)2.91 x 4.09 x 2.28" / 74 x 104 x 58 mm
Weight1.28 lb / 580 g
OLED Display - GENTREE Bumble Bee 14.4V, 98Wh Micro-Size Li-Ion V-Mount
SKU: G-B50/98W 12AD
$315.00Price
    • OLED Display on front
    • OLED information
      ✔ Temperature
    • 1 x USB C Port / PD65W (Charge & Discharge Supported)
    • 14.4V 98Wh Li-Ion V-Mount Battery
    • Support up to Total 12A Draw
    • 12A Max. Draw from a D-Tap Port
    • 1 x D-Tap Port
    • GENTREE Bumble Bee 14.4V, 98Wh OLED Li-Ion V-mount Battery (12A)
