Run your V-mount camera or pro video accessory on the G-B100 14.4V, 195Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 13.5Ah and supports high-current draws up to 12A.
Capacity (Wh) | 195 Wh |
Amp-Hours | 13.5 Ah |
Accessory Port | 2 x D-Tap 1 x USB C Port (PD 65W/Charge & Discharge) |
Maximum Load (D-Tap Port) | 12 A ( D-Tap ) |
USB C Port | PD+PPS 65W Charge & Discharge |
Dimensions (W x H x D) | 5.8 x 3.8 x 2.3" / 146.0 x 97.0 x 59.0 mm |
Weight | 2.43 lb / 1100 g |
OLED Display - GENTREE G-B100 14.4V, 195Wh Li-Ion V-Mount Battery (12A)
- OLED Display on front
- OLED information
✔ Temperature - 1 x USB C Port / PD65W (Charge & Discharge Supported)
- 14.4V 195Wh Li-Ion V-Mount Battery
- Support up to Total 12A Draw
- 12A Max. Draw from a D-Tap Port
- No-Wire PCB design
- 2 x D-Tap Ports
GENTREE G-B100 14.4V, 195Wh OLED Li-Ion V-mount Battery (12A)
