The robust G-B100 14.4V, 290Wh Li-Ion Battery from GENTREE provides power for your V-mount camera or pro-video accessory.
The 20Ah G-B100 battery also offers two D-Tap ports one USB C port which is PD 65W, Charge and Discharge supported.
G-B100 series batteries are designed as shock- and short-proof, and feature a wireless internal PCB design that dissipates heat.
A OLED display shows the Remaining time, Voltage, Current, Cell Life Cycles, Temperature, which enable to monitor and manage the battery health, ultimately it enhances battery maintenance routine.
Compact, shockproof, and short-proof design.
Cable-free design minimizes heat, prolonging battery life.
Capacity (Wh) | 290 Wh |
Amp-Hours | 20 Ah |
Accessory Port | 2 x D-Tap 1 x USB C Port (PD 65W/Charge&Discharge) |
Maximum Load (Accessory Port) | 12 A ( D-Tap ) |
USB C Port | PD+PPS 65W Charge & Discharge |
Weight | 3.4 lb / 1540 g |
Packaging Info | |
Package Weight | 3.85 lb |
Box Dimensions (LxWxH) | 7.4 x 4.9 x 4.1" |
OLED Display - GENTREE G-B100 14.4V, 290Wh Li-Ion Battery (V-Mount)
- OLED Display on front
- OLED information
✔ Temperature - 1 x USB C Port / PD65W (Charge & Discharge Supported)
- 14.4V 290Wh Li-Ion V-Mount Battery
- Support up to Total 12A Draw
- 12A Draw from a D-Tap Port
- No-Wire PCB design
- 2 x D-Tap Ports
