Run your V-mount camera or pro video accessory on the G-B100 14.4V, 290Wh Li-Ion Battery from GEN ENERGY. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 20Ah and supports high-current draws up to 15A. Two integrated D-Tap ports allow you to run accessories directly from the battery, and a USB C port is PD 65W, which now allows you to charge and discharge features.
Capacity (Wh) | 290 Wh |
Amp-Hours | 20 Ah |
Accessory Port | 2 x D-Tap 1 x USB C Port (PD 65W/Charge&Discharge) |
Maximum Load (Accessory Port) | 5 A ( D-Tap ) |
USB Output | 5 V, 2.3 A |
Charging Temperature | 32 to 104°F / 0 to 40°C |
Weight | 3.3 lb / 1520 g |
Packaging Info | |
Package Weight | 3.85 lb |
Box Dimensions (LxWxH) | 7.4 x 4.9 x 4.1" |
OLED Display - GENTREE G-B100 14.4V, 290Wh Li-Ion V-Mount Battery (15A)
- OLED Display on front
- OLED information
✔ Temperature - 1 x USB C Port / PD65W (Charge & Discharge Supported)
- 14.4V 290Wh Li-Ion V-Mount Battery
- Support up to Total 15A Draw
- 12A Draw from a D-Tap Port
- No-Wire PCB design
- 2 x D-Tap Ports
GENTREE G-B100 14.4V, 290Wh Li-Ion V-mount Battery (15A)
