Run your V-mount camera or pro video accessory on the G-B100 14.4V, 98Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 6.8Ah and supports high-current draws up to 12A.
Mount / Series TypeV-Mount
Capacity (Wh)98 Wh
Amp-Hours6.8 Ah
Output Voltage14.4 VDC
Accessory Port2 x D-Tap
1 x USB C Port (PD 65W/Charge & Discharge)
Maximum Load (D-Tap Port)12 A ( D-Tap )
USB C PortPD+PPS 65W Charge & Discharge
Charging Voltage16.8 VDC
Discharging Temperature-4 to 122°F / -20 to 50°C
Dimensions (W x H x D)5.8 x 3.8 x 1.6" / 146.0 x 97.0 x 39.0 mm
Weight1.45 lb / 680 g
OLED Display - GENTREE G-B100 14.4V, 98Wh Li-Ion V-Mount Battery (12A)
SKU: G-B100/98W 12AD
$279.00Price
    • OLED Display on front
    • OLED information
      ✔ Temperature
    • 1 x USB C Port / PD65W (Charge & Discharge Supported)
    • 14.4V 98Wh Li-Ion V-Mount Battery
    • Support up to Total 12A Draw
    • 12A Max. Draw from a D-Tap Port
    • 2 x D-Tap Ports
    • GENTREE G-B100 14.4V, 98Wh OLED Li-Ion V-mount Battery (12A)
