The robust G-B100 14.4V, 390Wh Li-Ion Battery, called as MONSTER battery, provides power for your large foramt camera and LED lights demanding high power Watts.
The 27.2Ah G-B100 battery also offers two D-Tap ports and one USB C port which is PD 65W, Charge and Discharge supported.
G-B100 series batteries are designed as shock- and short-proof, and feature a wireless internal PCB design that dissipates heat.
A OLED display shows the Remaining time, Voltage, Current, Cell Life Cycles, Temperature, which enable to monitor and manage the battery health, ultimately it enhances battery maintenance routine.
  • SPECS
    Mount / Series TypeV-Mount
    Capacity (Wh)390 Wh
    Amp-Hours27.2 Ah
    Output Voltage14.4 VDC
    Min. Discharge Power312 W, 26 A
    Accessory Port2 x D-Tap Ports
    1 x USB C Port (PD 65W/Charge&Discharge)
    Min. Discharge Power (D-Tap Port)144 W, 12 A (D-Tap)
    USB C PortPD+PPS 65W Charge& Discharge
    Charging Voltage16.8 VDC
    Discharging Temperature-4 to 122°F / -20 to 50°C
    Dimensions (W x H x D)5.8 x 3.8 x 3.8" / 146.0 x 97.0 x 97.0 mm
    Weight4.5 lb / 2040 g
OLED Display - GENTREE MONSTER 390Wh Li-Ion V-Mount Battery (26A Max. Discharge)
SKU: G-B100/390W 26AD
$749.00Price
    • OLED Display on front
    • OLED information
      ✔ Temperature
    • 1 x USB C Port / PD65W (Charge & Discharge supported)
    • 14.4V 390Wh Li-Ion V-Mount Battery
    • Support up to Total 26A Draw
    • 12A Draw from a D-Tap Port
    • 2 x D-Tap Accessory Ports
  • GENTREE G-B100 14.4V, 390Wh Li-Ion V-Mount Battery (26A)
