Postium Korea PRM-102F Overview
The Dual 10” Full HD LCD Multi-Channel Rack Monitor from Postium features two 10” full-resolution 1920 x 1200 LED backlit LCD panels. The 4RU monitor provides front panel individual control of brightness, contrast, chroma, audio volume and more. Its features include waveform (Y/Cb/Cr)/VectorScope, wide angle view and support for HDMI to SDI cross converting. Inputs include two 3G-SDI with active loop through plus component analog, S-Video, HDMI, three composite analog inputs, RJ45 remote control, and USB firmware upgrade port. Outputs include one SDI, one HDMI and one stereo mini audio out.
  • Color calibration for optimal luminance, gamma, and color temperature
  • Supports 3G-SDI (Level A/B) and 10-bit signal processor
  • HDMI-to-SDI and SDI-to-HDMI converter
  • Horizontal/vertical level meters
  • Battery level indicator with Auto Tally on when recording
  • Auto Luminance Control feature with Auto Color Temperature Adjustment and Auto H/V Flip
  • Still Image Overlay (SDI/HDMI, when this function is activated, Auto Flip is not working)
  • PIP, PAP (between analog and digital input)
  • USB memory update, Focus Assistance, and False Color features
  • Waveform and Vector Scope features
  • Closed caption (CEA-608/708) and time code (except 3G level B)
  • 8 to 16-channel audio level meter and exposure range check
  • UMD/IMD Mode - AFD & V-CHIP (SDI Only)
  • Various markers (EBU, 4:3, 16:9, 1.85:1, 2.35:1, etc)
  • H/V Delay, Pixel-to-Pixel View, Zero/Under/Over Scan, Blue/Mono, Fast Motion Mode
  • Tally LED control output and R/G/B/W internal patterns
  • Postium Korea Dual 10" Full HD LCD Multi-Channel Rack Monitor
  • DC Power Adapter
SKU: PRM-102F
$4,422.95Price
