Postium Korea OBM-H120 Overview
Monitor your production in the studio, on the field, and even in broad daylight with the OBM-H120 12" Super Bright Daylight Viewable LCD Monitor with 3G-SDI from Postium Korea. With 1280 x 800 display resolution and a 178° viewing angle, the monitor boasts a brightness of 2000 cd/m² and a 1000:1 contrast ratio. It features two 3G-SDI inputs and two 3G-SDI outputs, one HDMI 1.3a input and one output, which all provide options for bringing in video with embedded audio, while a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. There are also component and composite inputs for analog video. The monitor comes with its own power cord.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content. The OBM-N310-NB supports PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma and S-Log3. Postium's HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
- Postium Korea OBM-H120 12" Super Bright Daylight Viewable Monitor
- Power Cord
- Limited 1-Year Manufacturer Warranty (LCD Panel)
- Limited 2-Year Manufacturer Warranty
- For Daylight Monitoring
- 1280 x 800 Display Resolution
- 178 / 178° Viewing Angle
- 2000 cd/m² Brightness, 1000:1 Contrast
- 2 x 3G-SDI Inputs & 2 x 3G-SDI Outputs
- Component, Composite & HDMI 1.3a Inputs
- Power Cable Included
