Postium Korea OBM-N101 Overview
Monitor your studio or field production with the OBM-N0101 10.1" 3G-SDI/HDMI Broadcast LCD Monitor from Postium Korea. With a 1920 x 1080 display resolution and a 170° viewing angle, the monitor boasts 320 cd/m² brightness and an 800:1 contrast ratio. It features two 3G-SDI inputs and two 3G-SDI outputs, plus one HDMI 1.4a input and one output, all providing options for bringing in video with embedded audio, while a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. There are also component and composite inputs for analog video. The monitor comes with its own power cord.
Focus Assist controls the aperture level of a video signal and displays images on the screen with sharpened edges to help camera focus operation.
Various Frame Markers and Mattes
Connect via Ethernet and control your monitor remotely on the network. The System Date Copy Function allows users to save the monitor configuration and adjustment settings and load them to other monitors. This is useful for multiple monitor systems, allowing the transfer of one monitor's setup and adjustment data to another or many.
  • Postium Korea OBM-N0101 10.1" 3G-SDI/HDMI Broadcast LCD Monitor
  • Limited 1-Year Manufacturer Warranty (LCD Panel)
  • Limited 2-Year Manufacturer Warranty (Main Board)
SKU: OBM-N101
$2,845.00Price
    • 3G-SDI & HDMI Input/Output Connectivity
    • Component & Composite Analog Inputs
    • 1920 x 1080 Display Resolution
    • HDR & SDR Modes
    • 170 / 170° Viewing Angle
    • 320 cd/m² Brightness, 800:1 Contrast
    • Power Cable Included
