Postium Korea OBM-N210 Overview
Monitor your studio or field production with the OBM-N210 21.5" Broadcast LCD Monitor with 3G-SDI & HDMI from Postium Korea. With 1920 x 1080 display resolution and a 178° viewing angle, the monitor boasts a brightness of  400 cd/m² and a 1000:1 contrast ratio. It features two 3G-SDI inputs and two 3G-SDI outputs. one HDMI 1.3a input and one output, which all provide options for bringing in video with embedded audio, while a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. There are also component and composite inputs for analog video. The monitor comes with its own power cord.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content. The OBM-N310-NB supports PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. Postium's HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
False Color indicates the luma (Y) level of the input image. If a certain Y level is set, the pixels with the designated Y level are displayed with a zebra pattern or a color pattern. There are multiple display modes: zebra, variable, ARRI, and comparison.
  • Postium Korea OBM-N210 21.5" LCD Monitor with 3G-SDI
  • Limited 2-Year Manufacturer Warranty
SKU: OBM-N210
$3,557.00Price
    • For Mobile Broadcasting & Film
    • 1920 x 1080 Display Resolution
    • 178 / 178° Viewing Angle
    • 400 cd/m² Brightness, 1000:1 Contrast
    • 2 x 3G-SDI Inputs & 2 x 3G-SDI Outputs
    • Component, Composite & HDMI 1.3a Inputs
    • Power Cable Included
