Postium Korea OBM-R210 Overview
Monitor your field production from a mobile truck with the OBM-R210 21" Rack-Mountable 3G-SDI LCD Monitor from Postium Korea. The 7 RU rack-mountable monitor features a narrow bezel, making it ideal for OB van configurations, and it offers 1920 x 1080 display resolution with a 178° viewing angle, 1500 cd/m² brightness, and a 1000:1 contrast ratio. It features two 3G-SDI inputs and two 3G-SDI outputs. An HDMI 1.3a input provides an additional option for bringing in video with embedded audio, and a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. The monitor also has analog component and composite video connectivity and comes with its own power cord.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content with support for PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. The HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
Built-in Camera Log to Linear Conversion LUTs
The monitor has built-in Camera Log to Linear Conversion LUTs from various camera manufacturers, including Log-C, C-Log, S-Log2, S-Log3, J-Log1, and more. Plus, custom 3D LUTs can be imported for accurate and consistent color matching between different displays and for DIT previews of customized 'looks' that have been created by third party color-grading applications. The LUT-converted content can then be output to downstream devices/monitors via the SDI loop out.
- Postium Korea OBM-R210 21.5" Rack-Mountable 3G-SDI LCD Monitor
- Power Cord
- Rack Mount Kit
- Limited 1-Year Manufacturer Warranty
- Limited 2-Year Manufacturer Warranty
- For Mobile Broadcasting & Film
- 1920 x 1080 Display Resolution
- 178 / 178° Viewing Angle
- 1500 cd/m² Brightness, 1000:1 Contrast
- 2 x 3G-SDI Inputs & 2 x 3G-SDI Outputs
- Component, Composite & HDMI 1.3a Inputs
- Power Cable Included
