Postium Korea PRM-434 Overview
The Quad 4.3" LCD Multichannel Rack Monitor with 3G-SDI from Postium Korea is a very versatile, multichannel rack monitor that features four 4.3” 800 x 480 LCD panels with an 800 cd/m² brightness and a 15:9 aspect ratio on each display, into a 2 RU rack unit designed for 3G-SDI signal monitoring. The front panel provides access to a variety of functions, including embedded audio level, waveform, and vectorscope. Inputs and outputs include 3G-SDI in/out, capable of handling signals up to 1080p60, and a BNC composite input for analog video. An RS-422 input and output provide control, and a USB-A port is integrated into the rear panel of the unit for firmware updates and color calibration.
- Multi-format support (480i, 576i, 720p, 1035i, 1080i, 1080p, 1080PsF, 2K)
- Four high-resolution (800 x 480) 4.3” 15:9 wide screens
- Small footprint occupies only 2 RU of a standard EIA 19” rack
- Various scan modes
- RJ45 ports for remote control on each display (tally)
- RS-422 input and output
- USB-A port for firmware updates and color calibration
- H/V delay
- Blue only
- Internal pattern display
- Custom markers
- 3G/HD/SD-SDI input and output per display
- Composite input
- UMD (TSL 3.1)
- Audio level meter
- Timecode display
- Selectable waveform/vectorscope
- Postium Korea Quad 4.3" LCD Multichannel Rack Monitor with 3G-SDI
- DC Power Adapter
- Power Cord
- Limited 1-Year Manufacturer Warranty (LCD Panel)
- Limited 2-Year Manufacturer Warranty (Main Board)
- 2 RU Multichannel Quad Rack Monitor
- 800 x 400 Resolution & 15:9 Aspect Ratio
- 800 cd/m² Brightness
- 3G-SDI Input & Output Supports 1080p60
- Supports RS-422 Control
