DIGITAL FORECAST UHD X_TS Overview
Convert and ensure that your video signals are functioning properly using the UHD X_TS Troubleshooter 12G-SDI/HDMI 2.0/Optic Converter from DIGITAL FORECAST. This multi-platform unit works as an up/down/cross/scan signal converter, test-pattern generator, and signal integrity tester. It supports up to UHD 4K60 video resolutions and offers 12G optical fiber, 12G-SDI BNC, and HDMI 2.0 inputs and outputs.
Any input can be converted to any available output, and all outputs are simultaneously active. This converter features a 7" touchscreen display, up to 8-channel embedded audio monitoring, and a speaker output.
Power the unit using a V-mount battery or the included 12V power supply.
* 12G SFP Module sold separately
UHD X_TS 12G-SDI/HDMI 2.0/Optic Converter with Measurement & Pattern Generator
- UHD 4K Up/Down/Cross/Scan Converter
- 12G-SDI/HDMI 2.0/12G Optic Input/Output
- 1024 x 600 7" Touchscreen Display
- Test-Pattern Generator: Still and Moving
- Supports up to UHD 4K60 Resolutions
- EYE monitoring Measurement for SDI signal (720p, 1080i, 1080p, 2160p)
- SDI signal integrity check (Loss, CRC)
- HDMI 2.0 Signal Integrity Checks (Loss, Resolution, HDCP)
- Playback through SD card slot
- Embedded Audio, 8-Ch Monitoring
- Speaker Output
- V-Mount Battery Mounting Plate
